Please help me.
WeatherBug is rooted in Samsung Galaxy S. How do I remove it? Will it be okay if I switched from iPhones 3GS to Samsung Galaxy S2?
This is an urgent query. Kindly respond at the earliest.
Bye,
Everett Divorce
Weatherbug is rooted in Samsung
Hello Everett Divorce,
For sure you can remove Weatherbug in you Samsung galaxy S. Your phone should first of all be rooted properly for you to be able to remove the Weatherbug successfully. You will just need to go into the system application and then look for the Weatherbug and ticker application and delete them.
Otherwise for some phones you will need to go to the phones menu and from there locate the settings. Open the settings and the choose applications, and next choose manage applications. You should see the Weatherbug somewhere there, just delete it to remove from your phone.
Regards
Clair Charles
Dear,
To remove Weatherbug you uninstall the software. From the Samsung Galaxy S homescreen, Go to menu – settings – applications – manage applications – find Weatherbug – uninstall.
Thank you.
