I would like to know if a remote server can be used with EssentialPIM. And also, I am looking for a web hosting service that can support Firebird database and would work with EPIM network. Do you have any ideas? Help me. Thanks.
Web Hosting service that supports EPIM and Firebird Database
EPIM utilizes Scarlet tanager databases motor. You can accessibility databases straight making use of any Scarlet tanager database supervisor.For instance: http://www.mitec.cz/ibq.html Take note that you should understand how to work with database, otherwise data will be lost.Â
SQLÂ Editor in chiefÂ
This includes SQL Editor having phrase structure highlighting with Result Buffer. You can operate any kind of type of sql content or software. Output is flushed to formatted text message, not to power system, what it enables more flexible and synoptic end consequence overview.Â
You can even export/import info to/from CSV, XML, raw batch file or inkjet printing device.Â
Each and each properly work message is actually stored with inside SQL Past Fan. You are able to open several instances of this particular editor to run "simultaneous" queries.Â
Object ExplorerÂ
Here you can inspect each and each databases object including its detail properties. A few object you are able to redact too. Also you can extract meta data regarding all objects which includes info regarding stands.Â
Event WatcherÂ
Right the following you are able to inspect user defined event triggering.Â
Overall efficiency MonitorÂ
This tool enables profile and watch databases trading transaction. It contains pursuing faculties:Â
Mental representation utilization associated with watched databasesÂ
Number of composes and examine to data source and to aficionado cacheÂ
Person SupervisorÂ
Allows you increase, edit as well as remove data source customers and offices.Â
Grant ManagerÂ
Permits to grant or even revoke privileges in all data source objects.Â
EmploymentÂ
Allow me to share obtainable pursuing services:Â
Server Log Look atÂ
Dining-room attendant Attributes SummaryÂ
Data source Data OverviewÂ
Database Affirmation Task
Thanks
Regards
Jackson
