I have been doing hardware sizing for web logic server from SOA suite and AIA.
There are a lot of environments are using.
Please suggest me the required RAM & Disk size and CPU.
I will thankful for all help and suggestions.
If anybody knows how to fix this problem, please let me know.
I will thankful for all help and support.
Web Logic Server from SOA and AIA
There are two types of requirements
1 for the UNIX based systems
2 for the Windows based systems
UNIX based systems
The UNIX based systems requires any compatible LINUX package installed in it.
Minimum intel xeon dual core processor with 2.6ghz
Minimum 4GB of RAM if you are opting to run only 1 server on it. For two servers, double it.
Harddisk as required.
Minimum intel xeon dual core processor with 3.0ghz
Minimum 8GB of RAM if you are opting to run only 1 server on it. For two servers, double it.
Note that these are optimal requirements that are tested and do not give any lag or slow performance in real time environment.
