mattewgems
1300 points
Posted on - 06/16/2011
Hi friends,
While I was browsing the internet, i came across a site that I found in search engine that gave me an interest. In the process of loading that web page, a message appears that tells me internet explorer cannot open the site.
Internet Explorer cannot download document – 5.aspx from localhost.
Internet Explorer was not able to open this Internet site. The requested site is either unavailable or cannot be found. Please try again later.
OK
Normally, I checked my internet signal if it failed, but it's up and running. I also restarted my computer, so as my internet router. I tried using my Mozilla Firefox, but the more error it flashes that the more I cannot understand what it says. I decided to better concentrate on the error given by internet explorer, since it's quite easy to understand.
I posted the screenshot here for some help.
Web page error loading issue
There could be many errors in your website you want to surf the website you need to surf may contain any Java program or some other components that need some up gradation in your program and that's the reason it is not opening and giving you the error.
So to solve this problem you can make an update to your Java program also see in the update of all other components that are required to run your site. If the site contains some special type of language or component then you must need to first make an update to your system for such language or component and then you can run your site.
The other reason is that your Explorer settings are not valid and they are not working properly. So to solve this problem you can go to START and then to control panel here select internet options and change them to your default settings.
Once you have default settings then the browser will run as it was on the first day of installation. Also check some antivirus on your system and make your system error free and I am sure your problem will be solved.
Karen cruise.
