Web page loads to Google Chrome Security Certificate Error
I open a webpage, but the page loaded to a Google Chrome Security Certificate Error.
Certification Error Navigation Blocked – Windows Internet Explorer
There is a problem with this website's security certificate
The security certificate by this website was issued for a different website's address.
Security certificate problems may indicate an attempt to fool you or intercept any data you send to the
server.
We recommend that you close this webpage and do not continue to this website.
Is there a way to open it and related pages without receiving errors?
I expect your suggestions.
Best Answer by Hathy greave
Answered By 0 points N/A #132700
The main cause of the error 'secure certificate error' is the computer date and time. If you get the a security certificate invalid or expired error in Google chrome, first you have to change your computer systems date and time.
Have you corrected it?
Now you can go to the website with Google chrome. If you see the same problem again, continue to the website anyway update the security certificate on it.
Have you done it?
I think your problem has been solved.
Hathy
Answered By 0 points N/A #132701
Dear user,
This error appears because your computer clock is set so that the date/time is later than the expiry date of the web server’s SSL certificate.
To fix this
You can easily fix your time and date. And proceed with it.
If you want to work around this you can click continue to this web site (not recommended?)
And install that certificate to your browser.
Thank you
