The web using Eraser interface the application displayed an internal error
I was checking for updates on the web using Eraser interface, the application displayed an internal error. Can you provide me the proper solution step by step to resolve this issue? What should I do to fix it? I really need your help to fix it. Thanks.
Value of ‘-21500’ is not valid for ‘Value’. ‘Value’. ‘Value’ should be Between ‘minimum’ and ‘maximum’. Parameter name: Value
Eraser
OK
Answered By 0 points N/A #176103
Hello Jeremy
The problem here is not in your computer or your OS, the problem is with the Eraser program itself, you see after the last update realest lot of clients complained about this exact problem.
According to the Eraser homepage uninstall and re-install your Eraser to see if that works, if not then make sure you have the latest windows installed where you can find it and download it here, and reinstall Eraser again.
In case that did not work too then downgrading to Eraser 5 is your last option, keep a track of the Eraser 6 updates in their homepage and wait till the announcement of a new update with a Fix to this problem.
