Hello all,
I'm having the same issue with the extended-in webcam my X59SR. I as of late updated to Windows 7 64-cycle, and it was working fine under Vista 32-digit. This appears to indicate a driver situation. I've uninstalled and reinstalled the driver from both the Asus locale and the producer locale. Nothing's working. I've attempted things said in this string with no fortunes. Any more musings? Much appreciated.
Webcam AF 200 Windows 7 64 bit
It is a clear symptom of incompatible webcam driver. Most of the 32 compatible driver software do not support with 64 OS. As you tried ‘Suyin’ webcam driver which did not solve your problem, you should try the Chicony Camera Driver.
The given page contains all the necessary drivers for your laptop.
The virtual webcam driver may support your OS.
Hello Isabellagregorey,
You may be facing problems with your webcam driver. Your webcam software may not be supported in Windows 7, 64-bit, because most of the time applications are different from the Windows 32-bit to the Windows 64-bit, so you must acquire Windows 7, 64-bit compatible webcam software, and then try again.
Hope it must work.
