Webcam C250 isn’t working with windows XP
Hello, I am using a webcam C250. I have downloaded the software of this webcam three or four times as far as I can remember. Every time I try to Install it or run it on my windows XP, a black screen appears and then a message comes forward. It says it has encountered a problem and needs to close. Can anyone help me please?
Best Answer by Sharath Reddy
Answered By 590495 points N/A #142638
If this happens when you install the driver for your webcam, maybe you should check if the webcam software supports Microsoft Windows XP or not. Normally, this thing only happens if the driver or the software is not compatible with your operating system and if this happens, the only possible remedy is to find a version compatible with your operating system.
Also, make sure to download the driver from the manufacturer’s website. Since you are using Webcam C250 then you are using a Logitech product. To download the correct driver for your webcam, visit Logitech Webcam C250 Driver Download. Select your operating system below and download the driver. It should work this time.
Since you are using Microsoft Windows XP, the minimum RAM required to use the webcam is 256 MB. The driver supports both 32-bit and 64-bit Windows XP.
Answered By 5 points N/A #200164
Please ensure that your operating system is updated. Also, visit the webcam manufacturer website and locate the drivers necessary for your system. Perform system maintenance:
  1. Defragment.
  2. Remove excess files and junk files.
  3. Wipe free space.
  4. Perform an antivirus scan.
You can also comb the OS website for driver bundles, which are driver packs that target specific devices from certain manufacturers.
Answered By 0 points N/A #200163
·         If you have old software of webcam C250 then your webcam cannot working correctly.
·         Some time may be your windows files corrupt during installation.
·         Sometime your downloading software have missing files.
·         May be your window does not support software.
 Please install the latest driver that is mention in the given link.
https://www.techspot.com/drivers/driver/file/information/12815/
