Webcam driver for HPDV2918TX laptop!
Anyone know how to find the webcam driver for windows 7 in my hpdv2918tx laptop? It all works in windows vista but hp official has not released the driver for windows 7 yet!
According to my research I found out that you can download and install software to use your webcam and I found that solution.
May I ask if your Webcam's application is Youcam? If it is a yes you may download and install the software in the internet. And I will give a link for you to have a easy download and access for the file sir
This is the link that I have found which is in the trusted site, you may use the site also for other downloads Cnet.
Hope it helps sir. Enjoy your stay here and have a Great day sir.
You’re right. Unfortunately, if you have an HP Pavilion dv2918tx laptop, the drivers available from the HP website are designed only for Microsoft Windows Vista both 32-bit and 64-bit. That’s why if you have Microsoft Windows 7, these drivers will no longer work and that’s a big problem.
But since your only problem is with the webcam, you can use third-party webcam software as replacement for the HP webcam driver. The webcam will still work the same as when it is using the HP driver. One webcam software you can use is MyCam. It supports Windows 2000, Windows 2003, Windows XP, Windows Vista, Windows 7, and Windows 8.
Go to MyCam Free Download to download. Another one you can use is ManyCam. It is a free webcam and screen recorder software. The latest version supports Windows 7, Windows 8, Windows 8.1, and Windows 10. For Mac, it supports OS X 10.9 Mavericks and higher. Go to ManyCam Free Webcam Software to download.
Another one is Yawcam. It is actually a short term for “Yet Another WebCAM software”. It supports Windows 2000, Windows XP, Windows Vista, Windows 7, Windows 8, and Windows 10. It requires JRE 6 or higher (Java Runtime Environment), Microsoft DirectX 9 or higher, and Windows Media Player 9 or higher. Go to Yawcam Webcam Software to download.
