Webcam image quality and impact on internet connection
I am currently looking into the purchase of a webcam. As at 2015, I would like to know the best resolution that can be obtained from a webcam. Also I have a 512mb internet connection, does this have an immediate impact on the image quality for videoconferencing? Does the quality of the webcam counteract this problem?
Answered By 0 points N/A #184722
You can use Microsoft LifeCam Cinema webcam.
Because lifecam cinema offers extra options that a number of its alternative camera models do not have, sort of a rotating neck that enables you to position the camera at nearly any angle, a broadband electro-acoustic transducer mounted on the highest to snag your audio further as video, lovely optical device to stay recordings and video chats crystal clear, and crisp 720p HD recording and video career. That electro-acoustic transducer conjointly comes bundled with noise isolation technology create|to form|to create} certain solely the meant sounds make it onto your recordings and therefore the folks you ask at the opposite end of your Skype chat are not distracted by noise outside your window. Plus, even supposing Microsoft solely touts its Windows compatibility, several of you noted that their cameras square measure OS X compatible.
