Hello there,
After installing my webcam and try to run it this error with DLL appeared. I have reinstalled the program several times and again this error. Anyone have any idea what is with this error? How can I solve it and why it doesn’t work after I did everything that the error says?
Thank you!
Cannot find import DLL may be missing, corrupt or wrong version File “dd10shrd.dIl’, function
“?setElementDisplay@CIsHtmICtrl@@IAEXPBDHH©Z’ (error 0)
OK
Webcam installation time dll file missing error shows
If this issue with the DLL file is caused by the webcam application you installed, maybe you should check if the webcam software is compatible with your operating system. It’s not normal for an application to have a DLL file problem if it is installed on a compatible operating system. This error can only happen if your operating system is not supported.
In this case, it would be best to check for the latest version of the software that supports your operating system. After doing some checking, it seems the missing or damaged DLL file is from or part of Dragon NaturallySpeaking for Windows developed by Dragon Systems, Inc. You can download the buggy DLL file from dd10shrd.dll Dragon NaturallySpeaking for Windows.
Download the ZIP file, unpack it and place it on the folder of the program requesting it, in this case, the installation folder of your webcam. After that, start the webcam software again and see if it works. You can also copy the DLL file in “C:WINDOWSsystem32” in case it didn’t work.
