Webcam show fatal error during the install of driver
Hi there,
When I want to install my webcam on my PC this error appears. I have enough space on my HDD on both partitions and I am a bit surprised about this error. Any solution ? What this error means and why is asking for lots of space ?
Thank you !
Fatal Error
An unexpected error occurred.
There is not enough space on the disk.
Answered By 590495 points N/A #179321
I don’t think that’s possible. You only see this if the program or the installation wizard detects that the drive doesn’t have enough free space. And also make sure that your webcam’s software supports your operating system. When installing a webcam, it always installs on the system drive or drive C. It will not prompt you if you want to install on a different drive.
To free up some space in drive C, click Start, All Programs, Accessories, System Tools then select Disk Cleanup. Select drive C then click OK. Check “Temporary files”, Temporary Internet Files, and Recycle Bin then click OK. Wait for it to finish then restart the computer. Check all items in the dialog box that consumes drive space.
Try installing the webcam software again. If you know the official website of your webcam, visit and download the latest driver that supports your operating system.
