guy golle
20 points
Posted on - 01/30/2013
Hello Experts,
I am using Windows 7 on my computer. To access my computer remotely I just enabled and upgraded WebDav (Web-based Distributed Authoring and Versioning). I don’t know which port will correspond to WebDav. Please tell me proper webdav port dlink to resolve my issue. Any ideas and suggestions are welcomed.
On webdav which port should be used?
Hello Guy,
I have a solution for your problem. The port number is 443 and only secure WebDAV is accessible. Also you should create an account for WebDAV if it is not configured by default. I will be very happy if this solution can help you. For any problems ask again I will find another solution. Wish you all the best ,Malone.
