WebEx Editor Export to WMP Error
The error says that 'Windows Media' Player 9.0 or later to convert the file 'Format WMP'.
WebEx
Windows media Player 9.0 or higher is required to convent the file to.wmv format.
I do not know anything about this error. If someone knows it, I helped myself to solve this problem…
Answered By 0 points N/A #198973
Hey,
I understood your problem if I am not wrong you want to remove the error of converting the file into .wmv format.
You need to sign up for a trial Webex account to locate the latest version of webex editor. After downloading latest versions remove all other previous versions then you will be able to convert WRF files to WMV. For more you can visit the following latest version.
Hope this will fix your problem.
Thanks & Regards,
Gillam Janetj
