Hey people,
I am looking for some software like EZdrummer Acoustica mp3 to wav converter… Can anyone please suggest a good website from where I can download such sound mixing software?
Thanks for your help in advance.
Website to download software like ezdrummer acoustica mp3 to wav
Hi there Lauraj,
Mixpad Audio Mixer could suit your like. This is digital software that can mix hundred (100) tracks simultaneously (all at once), within the conversion from the original format, to the most common Audio formats.
And also it has Toolbox utility for editing purposes. Here’s the link (site) where you can download this application for free. http://download.cnet.com/MixPad-Masters-Edition/3000-2170_4-10580119.html
I hope you like it.
Regards.
Hey there,
If you are looking for a good quality mixing software, try to download mixpad on the link below. Here's the list of features on what the mixpad can do.
Mix an unlimited number of music, vocal and audio tracks
Record single or multiple tracks simultaneously
Load any audio file; more supported formats than any other mixer
Add audio effects including EQ, compression, reverb and more
Includes a royalty-free sound effect and music library with hundreds of clips to use in your productions
Convert to other files format.
VST plugin support for added studio effects and instruments
Very low latency, ASIO support for sample accurate recording
Supports sample rates from 6 kHz to 96 kHz
Export at all popular bit depths up to 32 bits floating point audio
Mix to mp3, burn to CD or upload your productions
Save in any file type you need, from studio quality wav files to high compression formats for sharing online
Hope this helps.
