I need the entire driver for all computer models. Just compress the files then save it as one file such as rar or cab file, as opposed to having to download drivers for a computer in isolation for each device. Does anyone know a site that provides those services? If there is no website available, just send an individual file with manufacturers supplying the driver packs for IT techs. Only Dell has the entire consumer support driver downloads websites that has them and they started providing driver packs that helped OS deployment. Websites like www.driverguide.com have been mentioned but these are usually out-of-date and also individual.
Website with the entire drivers for all computer models
I don't think that you can find the whole driver software in one single website. But you can find most of them in sites like hotfile, deposit file or sites like rapidshare.com. Here, i am sending the download link for you of more than 2GB of driver softwares compressed to 900MB. divided into 5 parts. all you have to do is to download all of them and extract them into one folder. I am sure that you can find almost all drivers from this mega pack.
Part1. www.depositfiles.com/files/ocukvsca0
Part2. www.depositfiles.com/files/p9p3bw7fb
Part3. www.depositfiles.com/files/7msi62ckb
Part4. www.depositfiles.com/files/rz0alrir7
Part5. www.depositfiles.com/files/ocukvsca0
I hope that you will get what you have been looking for.
Cheers.
What you are referring to, as in the website where you can find all drivers for a computer model, is basically referred to as the manufacturer's website. And there are several manufacturers’ websites that you can access to get the drivers for the model of the computer that you want. Below are some of the major manufacturer's websites:
The HP Website.
The Toshiba website.
The DELL website
The Acer website
But in case you need to get all drivers for the entire computer models that exist, then you will need to access the websites that offer those kinds of services, and one of them is DriverZone.
You only need to specify the kind of drivers that you want and the computer model to download them.
Clair Charles
