Gauravi
10 points
Posted on - 08/29/2011
Hi All,
Website free spellcheckers. Are there any available?
Is there a spellcheker that can check my website and report back with all spelling mistakes via email or a downloadable report.?
Thank you
Hi there.
To make a strong 1st impression for your clients, make sure your website is free from spelling errors. You can try these websites.
Hope you can try these sites and provide feedback here if which one suits your reference.
There are websites available that has spell checker tool, free and available for download. Spell checker helps you identify the error during typing. Every error you’ve made will make the word underline with red color. This inform you that you have type the word incorrectly. Spell check does all this and this is the most helpful tool that you need to have.
If you are not confident enough or just plain crazy enough to double check the spelling, then you need to have this kind of software installed in your computer. There are websites available on the Internet, ready for download. Some ask for charges and some are free. But the good thing is, either way paid or not, this is still a very helpful tool to have.
These websites are good example and has the tool to check spelling and send a report back to you. Whenever it detect mistakes, then it trigger by sending a messages to your email address.
Check this out and it’s really helpful if you are a blogger, writer and just for plain use.
