Website that Translate Languages into Different Language
Hi guys,
I am just curious about what are those language changer website? Or any website that can translate or change any language in to another language in an easy manner for we people need to have conversations, chat with different kind of people all over the world especially when business related purposes. So I want to know about this for future use. I hope you can give me an idea.
Thank you.
Best Answer by Tennesse Viry
Answered By 0 points N/A #181910
Google Translator is one of the best tools which can be used for purpose of language conversion nowadays. It can convert any website in almost any language into your desired language within a few seconds and by just using a simple click. You can check this tool here: https://translate.google.com/ .
Another easy and helpful tool is Text Translator. Similar to Google Translator this can also convert any text to your desired language online. Check this out here: http://translate.reference.com/
Answered By 0 points N/A #181911
Hello
you can translate your website and make it available in more than 60 languages, by entering Google translate https://translate.google.com/
when you enter Google translate, in the bottom there is website translator, this is the URL
https://translate.google.com/manager/website/?hl=en
when you enter the URL add your website and your original language of your website, then after that, you will choose the language that you prefer to translate and they will translate it
