Wedding invitation creator you can recommend
Is there a software that can create wedding invitation? Any free or paid software that are easy to use because I am not familiar with Photoshop and any complicated graphic software.
I would recommend you to go for Apple Pages. It has a very good template library with 2 invitations as well. If you are a MAC user then You can easily find its ease of use. It's drag and drop feature is the best.
MS publisher is another desktop publishing platform which you can use.
You can also go for Printshop. It isn't for free but have their free trial versions. It provides quality design.
http://www.printshop.com/Â gives you full details on this.
Another software that can serve your purpose is PagePlusX3.
There are two solutions:
1. Create it online :
You can go on: start making your wedding card.
2. Use a software :
I suggest you to use Photo filter which can let you do with your picture:
If you are looking for a program that can easily be used to create wedding invitation cards, here are several you can try which can be used either on your phone or on the computer. First is the Wedding Invitation Card Maker app available on Google Play Store. It is an Android app you can install on your Android Smartphone.
With this app, you can create any wedding invitation design wherever you are. Once you have created a new design, you can then share it on WhatsApp, Facebook, and other social media sites. Your friends can then RSVP your invite and you will have a list of people attending or not attending the wedding party. It requires Android 3.0 and higher.
Another one you can try is PrintingPress. It contains everything you need in creating a stunning wedding invitation as well as other stationery. It costs $29.99 and supports Windows XP, Windows Vista, Windows 7, Windows 8, and Windows 10. You can also install it on OS X using Parallels or VMware Fusion.
It requires 1.2 GHz processor or faster, 2 GB RAM, 4 GB free hard drive space, optical drive, 1024 x 768 screen resolution, and internet connection for product activation.
