I have encountered an unfamiliar error on my Windows 7 that I can’t explain why it happens. There is a random error that keeps on popping up either when I start my PC or after my antivirus has started. I am using AVG and I do not know if it is causing this problem. I just thought of asking the experts here so that I can get all possible causes of this error shown below.
Error Error
An error occurred while displaying previous error
Weird error on Windows 7
Hi wade
There are some errors that are fake so cause by a virus
I recommend you to restore your system by clicking the Start button/Control panel/select System/Advance system settings/choose system protection/then system restore/select next/continue through wizard/Restore your system before the date receiving the message/after completion reboot your computer. And there you have it.
Hi Wade S Veith,
To diagnose your computer and fix this error, you need to do the following:
1. Update your antivirus software and install the latest available version.
2. Scan your computer for malicious files and programs.
3. If malicious files are detected, follow the instructions provided by your antivirus software for file removal or deletion and for restoration of your computer registries.
Hope this helps.
Murakami Wyatt
