Welcome by an “error: Autolt Error”.
Good morning, every time I log in to my computer using Windows XP Pro, I am welcomed by an
Error: Autolt Error
Where could this possibly had originated from, since I only use the windows firewall and how can it be removed?
I’m in need of help in here.
Error:
Line 0 (File"c:WINDOWSsystem32Firewall.exe"):
$Second=$TimeandDate[10]
$Seconds=Error
Error: Array variable has an incorrect number of subscripts or subscript dimension range exceeded.
Answered By 0 points N/A #145328
try this solution:
First click on “Start” click "Run" then type in msconfig, and hit enter, and then click the "Startup" tab and search through the startup entries for”firewall.exe” and uncheck it, then click "Apply" and then "ok" and reboot the pc and once the pc has booted up you should get a "user configuration utility" window popup, click "ok" if this solution does not work…
Try this one:
 Click again on “Start” click "Run" then type in msconfig and then go to "Startup" tab and uncheck the entry related to "sscvihost.exe" and click “Apply”.  Restart your Windows.
Hope this help.
