Well Nuance’s Nina phone app work on all android phones
Hello All
I have just heard of a new voice powered web app called Nina by Nuance. I have a older android phone and was wondering if anyone new if it would work on  all android smart phones.
Thank You
Best Answer by Fosso pradha
Answered By 0 points N/A #130170
As far as this technology Nina by Nuance is concerned, It will work on any version of android as it is compatible with all android  devices. Nina by Nuance developers have made different API's (application programming interface) so its compatible on IOS and android devices.As the time goes on this technology can be used to other sectors for the betterment..
Answered By 0 points N/A #130171
According to their statement “The next big thing from Nuance is here and it will change the face of mobile customer services forever. ” After knowing some problems they clearly understood what is missing in siri.
Because siri is not supporting some applications like weather report, WiFi etc. Users are reporting problems about siri. Now they are making this new technology/application better than siri in iPhone 4s to overcome these problems. Anyhow it is not clearly mentioned what sort of phone will be able to use this application since this is an Android based app.
Many Android smart phones will be able to use this.
Answered By 10 points N/A #130172
Hello Carey,
The Nina app by Nuance is a Siri-like assistant that is meant to work on iOS as well as Android apps, and therefore as long as your phone is an Android phone this application must be able to work on it.
Some of the things Nina does are the following:
  • It authenticates – this application validates your identity using your unique voice print.
  • It navigates – It captures an intent in a single utterance and as well gets users precisely where they need to go to get their answer.
  • It transacts – With this app, you will be able to extract content, context as well as meaning from a request ensuring faster results in fewer steps.
  • It educates – You can learn how to get the most out of your virtual assistant, whether you talk, type or tap.
Carl
