kamal50
Posted on - 08/11/2011
In my Web Cam. This wave cam there is some trouble. One of them, when I am on the camera it is not work. This is so disgusting and boring. This is trouble me to work efficiently. Now I need why happen it and how recover it.
Smith1
Webcam problem in my computer
Dear it seems to me that the problem is in with your webcam driver. You never mention which windows are you using with this camera. Well you should just remove the camera driver and camera software and try to re-install the camera driver to follow these setups.
Right click on my computer then click on properties, then click on device manager, in the list of device manager's devices in other devices you can upgrade or reinstall the web cam driver and then try to restart the computer.
Might be the problem with you USB port try to change the camera USB port also it will work properly after these steps.
Steven66
Webcam is a very important part of a man's life nowadays. Many official or personal conferences have to make by it. So having a problem is really disgusting. You are having problem with your webcam.
You have to check that your webcam is connected perfectly.
Check that it gets power.
Check that your webcam driver is installed perfectly.
Check that your windows is able to find the webcam.
If your webcam is not connect perfectly, you may connect it. If it does not get power, your webcam may become damaged. If your webcam is not getting its driver install it correctly. If everything okay, but Webcam is not working then reset up your windows. If your webcam is become damaged then buy a new one.
