What About Microsoft Lumia 630 Dual Sim?
If I am not considering Microsoft Lumia 540 then should I consider Microsoft Lumia 630 dual sim? Is Microsoft Lumia 630 a smartphone worth to buy?
Well, if the smartphone is worthy or not, it particularly depends on the user instead of the viewers. Every person has his own taste. Each product has its own pros and cons whether it is an android, Microsoft or apple. Taking those pros and cons into account, you have to decide whether the product is worth to buy or not.
In my opinion, I will not suggest you, Microsoft Lumia, 30 dual sim. It does not contain the front camera. Its processor gets slow gradually after updated to windows 10, it starts hanging. It does not work properly. No doubt, it is a good phone, but if you want to buy a Microsoft phone, then check other options, don’t go for Lumia 630.
The Microsoft Lumia 630 Dual SIM is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on April 2014 and released on May 2014 measuring 129.5 x 66.7 x 9.2 millimeters and weighing 134 grams. It uses dual micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 480 x 854 pixels screen resolution.
It supports multi-touch protected by Corning Gorilla Glass 3 featuring ClearBlack display. It runs on Microsoft Windows Phone 8.1 powered by Qualcomm Snapdragon 400 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 305 GPU. It supports microSD expandable up to 256 GB. It runs on 512 MB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with autofocus featuring geo-tagging, panorama, and 1/4″ sensor size.
It supports 720p video recording at 30 fps. There is no secondary camera. It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 4.0 with A2DP and LE/aptX after WP8 Denim update, GPS with A-GPS and GLONASS support, FM radio, and microUSB 2.0. It has built-in accelerometer and sensor core sensors. The pre-installed web browser supports HTML5.
Java is not supported. It runs on removable BL-5H Li-Ion 1830 mAh battery with standby time up to 648 hours. Talk time is up to 16 hours 20 minutes on 2G and 13 hours 10 minutes on 3G. It is available in bright orange, bright green, bright yellow, white, and black colors.
