What About Microsoft Lumia 638 Dual Sim?
If I am not considering Microsoft Lumia 630 then should I consider Microsoft Lumia 638 dual sim? Is Microsoft Lumia 638 a smartphone worth to buy?
Well, if the smartphone is worthy or not, it particularly depends on the user instead of the viewers. Every person has its own taste. Each product has its own pros and cons whether it is an android, Microsoft or apple. Taking those pros and cons into account, you have to decide whether the product is worth to buy or not.
According to me, it is better than Microsoft Lumia 630. Microsoft Lumia 638 Dual sim is LTE supported, cheaper than Lumia 630 and has 1 GB RAM. No other difference lies between Lumia 630 and Lumia 638. It doesn’t contain a front camera. So, if you are thinking to buy Lumia 630, drop the idea instantly and go for Lumia 638.
The Nokia Lumia 638 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public and released on December 2014 measuring 129.5 x 66.7 x 9.2 millimeters and weighing 136 grams. It uses micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 480 x 854 pixels screen resolution.
It supports multi-touch protected by Corning Gorilla Glass 3 featuring ClearBlack display. It runs on Microsoft Windows Phone 8.1 powered by Qualcomm Snapdragon 400 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 305 GPU. It supports microSD expandable up to 256 GB. It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with 1/4″ and autofocus featuring panorama and geo-tagging.
It supports video recording but it has no secondary camera. It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 4.0 with A2DP and LE/aptX after WP8 Denim update, GPS with A-GPS and GLONASS support, FM radio, and microUSB 2.0. It has built-in accelerometer sensor. The pre-installed web browser supports HTML5.
It runs on removable BL-5H Li-Ion 1830 mAh battery. If you are looking for the dual SIM variant, they should have pretty close specifications.
