What About Microsoft Lumia 640 Dual Sim?
If I am not considering Microsoft Lumia 638 then should I consider Microsoft Lumia 640 dual sim? Is Microsoft Lumia 640 a smartphone worth to buy?
Well, if the smartphone is worthy or not, it particularly depends on the user instead of the viewers. Every person has its own taste. Each product has its own pros and cons whether it is an android, Microsoft or apple. Taking those pros and cons into account, you have to decide whether the product is worth to buy or not.
According to me, it is better than Microsoft Lumia 638. Microsoft Lumia 640 Dual sim is not LTE supported, but it has the 5.0-inch touch screen display, 720-1280 pixel screen resolution, upgradable to windows 10 through Microsoft update. In other phones, you have to put windows insider to upgrade to windows 10. It has 8MP back camera and 2.2 MP front camera. Even its battery is also more than Lumia 638, i.e. 2500 mAh Li-ion battery.
I think you should consider Lumia 640 instead of considering Lumia 638 as it is a good smartphone to buy. If you are thinking about budget issues, then today, Lumia 640 is available at affordable prices.
The Microsoft Lumia 640 Dual SIM is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on March 2015 and released on April 2015 measuring 141.3 x 72.2 x 8.8 millimeters and weighing 145 grams.
It uses dual micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 3 featuring ClearBlack display. It runs on Microsoft Windows Phone 8.1 upgradable to Microsoft Windows 10 powered by Qualcomm MSM8926 Snapdragon 400 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 305 GPU.
It supports microSD expandable up to 256 GB. It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 8 megapixels with f/2.2, 28mm, 1/4″, LED flash, and autofocus featuring geo-tagging. It supports 1080p video recording at 30 fps. The secondary camera supports 1 megapixel and 720p video recording.
It has 3.5-millimeter jack; Wi-Fi 802.11 b/g/n with DLNA and hotspot support; Bluetooth 4.0 with A2DP support; GPS with A-GPS, GLONASS, and BDS support; FM radio; and microUSB 2.0. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML5. It runs on removable Li-Ion 2500 mAh battery with standby time up to 840 hours both on 2G and 3G.
Talk time is up to 27 hours 30 minutes on 2G and 20 hours 30 minutes on 3G. It is available in matte black, glossy cyan, white, and orange colors.
Notifications
