What About Microsoft Lumia 950 Dual Sim?
If I am not considering Microsoft Lumia 640 xl black then should I consider Microsoft Lumia 950 dual sim? Is Microsoft Lumia 950 a smartphone worth to buy?
Well, if the smartphone is worthy or not, it particularly depends on the user instead of the viewers. Every person has its own taste. Each product has its own pros and cons whether it is an android, Microsoft or apple. Taking those pros and cons into account, you have to decide whether the product is worth to buy or not.
Having 5.2-inch display with 720*1280 pixel screen resolution contains windows 10 operating system by default. Having a 20MP back camera and 5MP secondary camera, it has 3000 mAh Li-ion battery and is LTE supported also. In conclusion, Lumia 950 is a better phone as compared to the Lumia 640 XL black.
The Microsoft Lumia 950 Dual SIM is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled to the public on October 2015 and released on December 2015 measuring 145 x 73.2 x 8.2 millimeters and weighing 150 grams.
It uses dual nano-SIM card and has AMOLED capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 3 featuring ClearBlack display. It runs on Microsoft Windows 10 powered by Qualcomm MSM8992 Snapdragon 808 chipset, Hexa-Core (4 x 1.4 GHz Cortex-A53 and 2 x 1.8 GHz Cortex-A57) processor, and Adreno 418 GPU.
It supports microSD expandable up to 256 GB. It runs on 3 GB RAM with 32 GB internal storage. The primary camera supports 20 megapixels with f/1.9, 26mm, 1/2.4″, 1.12 µm, Carl Zeiss optics, OIS, autofocus, and triple-LED RGB flash featuring geo-tagging, panorama, HDR, face detection, and PureView. It supports 2160p video recording at 30 fps with stereo sound rec. and 1080p at 30/60 fps (after SW update).
The secondary camera supports 5 megapixels with f/2.4 and 1080p video recording. It supports 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band and hotspot support; Bluetooth 4.1 with A2DP support; GPS with A-GPS, GLONASS, and BDS support; NFC; FM radio; and USB 3.1 Type-C 1.0 reversible connector. It has built-in iris scanner, accelerometer, gyro, proximity, compass, barometer, and sensor core sensors.
The pre-installed web browser supports HTML5. Java is not supported. It runs on removable Li-Ion 3000 mAh battery with standby time up to 288 hours both on 2G and 3G. Talk time is up to 23 hours on 2G and 18 hours on 3G. It is available in black and white colors.
