What is the Acer Aspire 5332 Bluetooth Activation Process?
Hi TechyV!
Does anyone know the Acer Aspire 5332 Bluetooth Activation Process? Can anyone please tell me? I cannot use my Bluetooth and it is not working. What seems to be the problem? Please help anyone. I would appreciate any personal blogs, tutorial lessons, books, ebooks, videos and any other way just to help me solve this problem. If you are an expert on this, then please help.
Thank you.
Answered By 0 points N/A #152120
Setting up and configuring Bluetooth on the laptop is simple.
Press the "Bluetooth" button beside the keyboard among the other application buttons. This turns on Bluetooth on your Acer 6920 and the button flashes blue.
Set up the other Bluetooth device (for instance, your phone) so the computer can find it. Make sure the device has Bluetooth enabled and is on "discoverable" mode. On most of the devices, you must go to the "Menu," "Settings," "Bluetooth," "On," then "Discoverable." The options may differ depending on the device.
Go to the "Start" menu on your computer.
 Select "Control Panel," "Hardware and Sound," and "Bluetooth Devices."
Click "Add." A Bluetooth setup wizard walks you through the configuration procedure
Answered By 590495 points N/A #314040
If you have an Acer Aspire 5332 laptop and you can’t activate or use Bluetooth, one reason is if you don’t have the driver installed. Though Bluetooth is built-in to the laptop, you have to install the driver first before you can use it. You cannot use it if there is no software running the device.
If you don’t have the CD that came with your laptop, you can always download the driver from the Acer website. To download the driver or software for your laptop, go to Aspire 5332 Product Support. Here, select your correct operating system. Drivers and software for Acer Aspire 5332 are available for Windows Vista and Windows 7 only both 32-bit and 64-bit.
Download and install all available drivers for your laptop. This should fix the problem.
