I was working on a document and was saving it when I got an error saying the document could not be saved. Did I do something to get acrobat save error 23 on my computer? The file is not so huge and I am wondering why I got the error. I have tried to optimize by browser and checked some settings but still got the same error.
What is acrobat save error 23?
Sometimes, saving with a different name works the trick. Also try to delete all registry entry for the application and install it once again.
As you have stated in the question above, check again the settings. Try to follow the procedure below:
Go to preferences, then click on 'general'.
Undo 'save as optimizes for fast web view '
See if the problem will get fixed. If the problem persists, contact the company whose document you are using.
