What is actually LAN IP add of Asus IP Router
I am actually confused by the Lan IP Address .What is actually LAN IP add of Asus IP Router? Can anybody help me to get the answer?
The LAN IP add of a asus router often called as the ip address of internal router. The internal ip address is also the ip address by which you connect to while configuring the router. This ip addres is not useful for the internet use and it has only use from the inside network.
Each and every router has two IP addresses, the external and the internal ip add. The service provider of Internet or ISP will assign you external IP and it is the ip address that you can't change generally. On the other hand, internal ip is usually set to default by the factory, but you can change it if you wish.Â
