annaatutor
40 points
Posted on - 12/19/2012
Dear experts, I have a few questions about using Joomla. I would like to know about an extension called Admin-User-Access? What is admin user access Joomla? Can you tell me what it does? Please tell me in a more detailed way, I would like to use it. Thanks in advance.
As the name implies, you can manage users with the use of this extension. This is pretty handy and helpful. Some of its features but not limited to include:
· Article access
· Page access
· Component access
· Admin-user access backend toolbar
· Custom toolbar buttons per user group
· Hiding of Joomla toolbar
You may download it at https://www.pages-and-items.com/extensions/old-extensions/admin-user-access/
Hi there Annaatutor,
Admin User Access is the component created to help you manage users and to give them more privileges that they should have within the Joomla core user management on your Joomla 1.0.x or Joomla 1.5 website.
Component is fast, stable and simple to be used. Once you install it, you will be able to give your registered users rights they couldn't have using the regular user manager. For example – using this component you can let registered users edit articles or enter your backend.
Best regards,
Drake Vivian
