James Craig
40 points
Posted on - 11/27/2012
Hello experts,
What's the difference between the other reader to this Adobe Reader Active X? For me, I think that the previous releases are way too good than this version but for some reason many people like this version so much. I've been trying hard to find the answer because if the answer is good then I need to install it and upgrade the previous version to this. Furthermore, can you give me a link where ca I download it? Thank you so much.
What is Adobe Reader Active X?
Adobe active x acts like a plug in for adobe acrobat reader, its use is to control the design tab or design menus of the adobe reader. This means that it is responsible for the architecture or the interface of the PDF reader as well as the file that is being executed by the Adobe reader. The only difference between the old version and the new version is that the speed on how they process.
https://en.softonic.com/s/adobe-reader-10-activex
Hope the link will help you.
Hi James Craig,
Definitely there are several features which makes adobe reader active x different from other software. When you will use it you come to know the differentiation between the software you were using and the present software i.e adobe reader active x you used.It has more features comparatively and believe it will be more reliable to you no doubt.
Please find the below attached linked in order to download a free adobe reader active x.
Thanks
