What is the advantage of fax server in VoIP?
Fax servers are known to have increased security, integrates with current office technology but what about in VoIP environments?  Fax servers connect to analog phone lines which is a problem to VoIP interfacing.  What is the advantage of Fax server in VoIP T.38 protocol?
Answered By 0 points N/A #165818
Hi Jose Fanjel,
The advantage of using fax server in VoIP T.38 protocol is:
1.  It provides better efficiency, concrete cost savings, and fax server Virtualization.
2.  Designed to preserve the traditional fax experience and at the same time ensure that faxes are successfully sent and
received.
3.   Makes adjustments for jitter, latency, and packet loss, which are inherent in all IP networks.
Hope, this solves your problem. Please let me know if, in case it doesn’t.
