What is the advantage of iPhone 5 to iPhone 4s?
Does these two versions of iPhone make some differences? I mean, these two are of the same apple software right? Then what's the advantage of iPhone 5 than iPhone 4s?
Hi, Muench! I was shocked to read your question – I did not know that Apple will launch iPhone 5! I browsed the web for some articles about this specified concern. After reading a lot of articles, I have found out that it is really true that Apple will launch iPhone 5 and that will be on September. Articles said that we should expect it to be thinner, has new speaker grilles and a smaller dock connector. There is a possibility that this phone will not be called iPhone 5. It will have a metallic color with faster processor, 3D like interface, the headphone jack is on the bottom, and much improved battery life.Â
Since you want to know about iPhone 4s and iPhone 5, I will simply describe the specifications of both devices and just check their differences yourself. For the Apple iPhone 4s, it is a 3G device operating on 2G and 3G network bands using GSM, CDMA, HSPA, and EVDO technologies. The Smartphone was unveiled and released at the same time on October 2011.
It measures 115.2 x 58.6 x 9.3 millimeters and weighs 140 grams. It uses a micro-SIM card featuring a scratch-resistant glass back panel. It has an LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 960 pixels screen resolution. It supports multi-touch and protected by Corning Gorilla Glass with oleophobic coating.
It runs on iOS 5 upgradable to iOS 9.3.2 powered by Apple A5 chipset, Dual Core 1.0 GHz Cortex-A9 processor, and PowerVR SGX543MP2 GPU. Unfortunately, it doesn’t support microSD. It runs on 512 MB RAM with internal storage available in the following capacities: 8 GB, 16 GB, 32 GB, and 64 GB.
The primary camera supports 8 megapixels with f/2.4, 35mm, LED flash, and autofocus. The primary camera features face detection, 1/3.2" sensor size, 1.4 µm pixel size, panorama, HDR photo, geo-tagging, and touch focus. The primary camera is able to record video in 1080p at 30 fps. It supports a secondary VGA camera that can record video in 480p at 30 fps with videocalling over Wi-Fi and 3G.
It supports 3.5-millimeter jack; Wi-Fi 802.11 b/g/n with hotspot; Bluetooth 4.0 with A2DP and LE; GPS with A-GPS and GLONASS; and USB 2.0. It has built-in accelerometer, proximity, compass, and gyro sensors. The pre-installed web browser, Safari, supports HTML5. Java is not supported. It runs on non-removable Li-Po 1432 mAh battery (5.3 Wh) with standby time up to 200 hours both on 2G and 3G.
Talk time is up to 14 hours on 2G and 8 hours on 3G. It is available in black and white colors. For the Apple iPhone 5, it is a 4G device operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies. It was unveiled and released to the public at the same time on September 2012.
It measures 123.8 x 58.6 x 7.6 millimeters and weighs 112 grams. It uses a nano-SIM card. It has an LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 1136 pixels screen resolution. It supports multi-touch and protected by Corning Gorilla Glass with oleophobic coating.
It runs on iOS 6 upgradable to iOS 9.3.2 powered by Apple A6 chipset, Dual Core 1.3 GHz Swift (ARM v7-based) processor, and PowerVR SGX 543MP3 (triple-core graphics) GPU. It also doesn’t support microSD. It runs on 1 GB DDR2 RAM with internal storage available in the following capacities: 16 GB, 32 GB, and 64 GB. The primary camera supports 8 megapixels with f/2.4, 33mm, autofocus, and LED flash.
The primary camera features touch focus, geo-tagging, 1/3.2" sensor size, 1.4 µm pixel size, face detection, HDR photo, and panorama. The primary camera can record video in 1080p at 30 fps. The secondary camera supports 1.2 megapixels, f/2.4, 35mm, and can record video in 720p at 30 fps with face detection and FaceTime over Wi-Fi or Cellular.
It supports 3.5-millimeter jack; Wi-Fi 802.11 a/b/g/n with dual-band and hotspot; Bluetooth 4.0 with A2DP and LE; GPS with A-GPS and GLONASS; and USB 2.0 reversible connector. It has built-in accelerometer, gyro, proximity, and compass sensors. The pre-installed Safari web browser supports HTML5. Java is not supported as well. It runs on non-removable Li-Po 1440 mAh battery (5.45 Wh) with standby time up to 225 hours both on 2G and 3G.
Talk time is up to 8 hours both on 2G and 3G. It is available in Black/Slate and White/Silver colors.
