MATLAB and its advantages compared to conventional computer
MATLAB means matrix laboratory . It is easy to use . The programs in MATLAB is easier than conventional languages . There is a sample program . It can be use in different operating systems. It has a lot of built in function to calculate any mathematical problem .
Yes ,
It is correct but is there another advantages .
There is very remarkable plotting feature in MATLAB .There any mathematical equation can be plotted .
In MATLAB it is possible to make image file for plots . It has also user graphic interface . By
this many device is controlled and monitored . By this image it will be clear .
The approach of MATLAB is like Microsoft visual basic .
It is also generate device independent p-code . So it is very helpful for mathematical operation .
