What affects the process of copying files
I possess a lot of files to be moved. I want to copy the files from my external hard drive. Copying is really a long process, it's only 1 MB / S even though it already wears a Teracopy. I'm thinking about what affects the copy process? Whereas before the copy process is fast at 15-20Mbps.
What is wrong with my computer?
Best Answer by lawrance
Answered By 0 points N/A #99263
Dear Margaret,
Nice to see this question here. Please don't worry about this issue. Sometimes we really encounter this kind of problem. Not only when it comes to copying, sometimes we also find that our computer is working very slow.  Now,  please press ctrl+alt+del, next, open task manager, then click process. And also, check how many programs are presently running. If you see that some unknown programs are running, then, please stop those programs and see what happens. Maybe, you will get a better performance. Another thing, please check performance tab and see how much is CPU usages
Please apply this process and if you get solution then, please reply with thanks.
Answered By 0 points N/A #99265
Yeah, I was already panicking, I'll try to check it again in the Task Manager and find out what programs are consuming large resource.
Thanks a lot, Lawrance.
