tia heyen
10 points
Posted on - 02/16/2013
Anyone here knows an affordable Android Spice 3g mobile phone? I'm looking for an Android touch screen phone with at least a 2 MP camera, SD card slot and internet connectivity (data and wifi). It's ok if it's not dual SIM. Any suggestions? I'm on a tight budget. Thanks.
What is an affordable Spice 3g mobile phone?
As per your requirements I can suggest Spice Mi-720, which have all the requirements you specified. One of the main advantage is its battery stand-by and talk time is amazing because of it have 4200 mAh Non-removable Li-Ion battery. Go through the link Spice Mi-720 for the detailed specification of the phone.
Ccharle William
Try out Spice Stellar Mi-285.
Touch and Type option for input.
Android OS
3.2 MP primary camera
WiFi enabled
Price less than 4000 INR
Another option, Spice Stellar Nhance Mi-435
Touch screen
Android US
8 MP primary camera and 1.3 MP secondary camera.
1GHz processor.
WiFi enabled
Price less than 8000 INR
Both these models have very good user reviews and gives a better battery backup.
