What is age of laptop?
After how many years a Laptop should be replaced with new one. What is Exact Age of a Laptop if i proper care a Laptop. Please tell me.
Laptops usually have 2 year guarantee, or for some brands 3 years guarantee. There are instances with 5 year life guarantee, Dell has laptops with 5 year guarantee. If your laptop is near to guarantee expiration,  and if you can see some of symptoms of aging laptop, you need to replace it. In many cases your cooler would not work properly, and keyboard gets buttons that have no operability. First, for a case that components get warmed up, there are notebook coolers for laptops, which are available commercially. As far as your buttons don’t have functionality, you can download virtual keyboard, and use it instead of regular keyboard.   It may be that you have insufficient RAM, or not enough Hard disk memory. But in this case, you can purchase only RAM and a new SATA Hard disk drive, with more memory.
If you decide to upgrade your existing system instead of replacing whole configuration, start with your RAM Memory, and SATA Hard disk. SATA disks are available at https://www.ebay.com/
The power plugs are weak end to laptop life, but this repair or replacement of battery adapter is not too expensive (20-50 USD ), and I recommend this to be done.
