What is an ajax tree mySQL? I need help.
I am a newbie in the world of database and I am reading and studying about mysql database. What is an ajax tree mysql? What are the scripts use for this kind of program and how it works?
Provide some website that will give the full information regarding this issue. Thank you
Best Answer by Whudson Audrey
Answered By 590495 points N/A #128565
SQL is the standard language for accessing databases. To learn how to use SQL to access and manipulate data in SQL Server, MySQL, Sybase, Access, Oracle, DB2, and other database systems, please visit SQL Tutorial.
Here are some of the SQL commands or functions that you can learn:
SQL Basic
  • SQL Syntax
  • SQL Select
  • SQL Distinct
  • SQL Where
  • SQL And & Or
  • SQL Order By
  • SQL Insert
  • SQL Update
  • SQL Delete
SQL Advanced
  • SQL Top
  • SQL Like
  • SQL Wildcards
  • SQL In
  • SQL Between
  • SQL Alias
  • SQL Joins
  • SQL Inner Join
  • SQL Left Join
  • SQL Right Join
  • SQL Full Join
  • SQL Union
  • SQL Select Into
  • SQL Create DB
  • SQL Create Table
  • SQL Constraints
  • SQL Not Null
SQL Functions
  • SQL avg()
  • SQL count()
  • SQL first()
  • SQL last()
  • SQL max()
  • SQLmin()
  • SQL sum()
  • SQL Group By
  • SQL Having
  • SQL ucase()
The site also offers a demo for you to learn the basics easily.
Answered By 0 points N/A #196816
It is possible to work with time tracking software. The Period Linens Expert software is actually AJAX or PHP or MySQL primarily based net app which allows you to course doing the job time associated with personnel, challenge expenses as well as a member of staff overall performance.
SQL may be the normal dialect pertaining to being able to access data source. For you to learn to work with SQL to access as well as change files with SQL Server, MySQL, Sybase, Admittance, Oracle, DB2, along with database techniques.
Pertaining to more information you can travel to:
Http: //www. Phpkode. Com/scripts/item/Ajax-tree-view-class-6315/
As well as
Http: //web4us. WordPress. Come/2009/12/18/tips-to-speed-up-your-mysql-queries/#more-546.
They will clear your view. Hope you sort out your problem.
