What algorithms does recovery toolbox for cd use?
What algorithms does recovery toolbox for cd use? I am wondering how this program works because it says it can recover data from CD, DVD, Blu-Ray etc. using various algorithms but what are these algorithms?
Answered By 30 points N/A #165274
Hi there Marie Philips,
Unfortunately, only the developers of the recovery toolbox can give you the answer to your question and i seriously doubt they would be pleased giving away their secret. However, the basics are always the same – every software uses some sort of algorithms in order to do something. I would suggest you to visit the following link to find out more about recovery algorithms, how they are used and how they work: https://en.wikipedia.org/wiki/Algorithms_for_Recovery_and_Isolation_Exploiting_Semantics.
Best regards,
Drake Vivian
