What is all about 2 way call recording Samsung Galaxy ace?
Hi guys,
What is all about 2 way call recording Samsung galaxy ace? I am only familiar with one way call recording using my computer but in the new trend of technology nowadays we can’t help but be interested on that stuff. A step by step process of 2 way call recording will help me to feed my curiosity.
Expecting some help, thank you.
Best Answer by Alcaraz Jody
Answered By 5 points N/A #180269
Hi Anthony,
In order for you to record 2 ways call using Samsung galaxy ace, you need to access the Google Playstore and download software first. Click on the search function then type in call recorder. There are a lots of software, but don’t worry most of them are free.
Hope it will help you.
Answered By 5 points N/A #180270
To feed your curiosity,
First 2-Way Call Recorder is an application for android operating systems; it is software for recording calls in your mobile phone it gives you a many options like recording internal calls, voice messages, recording with HD or normal recording. It also has backup options integrated with Gmail. You can download it from the link below with 60 seconds trail for free.
Answered By 590495 points N/A #327916
If you want to try two-way call recording on your Samsung phone, you can install an app that supports this feature. If you have a supported Smartphone, try downloading Call Recorder Automatic. Please check user feedbacks before downloading.
The app supposedly should record phone calls from both sides but according to some users, it is only your voice that is clear and the person on the other end of the line has a very low volume and almost can’t be heard. The latest version at the moment is Call Recorder Automatic 3.2.3 released on February 5, 2020.
It requires Android 5.0 Lollipop and higher. Call Recorder Automatic is rated 3+. Another app you can try is Automatic Call Recorder. The latest version at the moment is Automatic Call Recorder 1.1.101 released on July 30, 2019. It requires Android 4.0 Ice Cream Sandwich and higher. Automatic Call Recorder is rated 3+.
