Jean Moore
10 points
Posted on - 10/28/2012
Hello experts,
What is all about an anti idle software? What can an anti idle software do to all the users in the internet or any chat session? Give me some information that will probably clear up my mind regarding anti idle software. And also name some software which is very important for a research.
Thank you.
Anti idle software have the capability to stop the idleness feature. It is use to avoid clients from surpassing their bandwidth unintentionally. Most Anti idle software are prepared for Windows XP/9x/2000. It is the system to remain logged into a PC without being logged-off. This software allows your cursor moves each minute.
Best regards,
Heather marie
If you are using vista or windows 7 then i have option for you. Keep Alive is a software which you can use if you are using the vista or windows 7.
There is also software for only for those who use vista operating system and that is DUN Manager. This software is also very helpful.
Thank you.
