What is all about cartoon JavaScript?
What is all about cartoon JavaScript? I was asked to pick a specific theme for my program in my java programming class and I chose those cartoon characters and movies. I have to create a puzzle with cartoon character themes using javascript. How will I be able to do it and please suggest a software to be used.
Waiting for your support, thank you.
Answered By 0 points N/A #172203
Hi Debra,
You have to building a puzzle, piece by piece. You'll need a clip art image of a puzzle that can be ungrouped and modified in PowerPoint. When you ungrouped the puzzle clip art and change the fill color to match the background color of the side.
Place the image that you want to reveal underneath the puzzle image. Now you duplicate the slide and then remove a puzzle piece from the clip art. Continue to do this until the entire image is revealed.
