Hi everyone,
What is all about cookie cleaner windows open source? An open source for windows operating system that will enable to clean all the browser cookies, my default browser is Mozilla Firefox, I need some advice from the experts.
Hi Shannon!
You don't have to download and install any software for clearing your browser's cookies. You can automatically clear it by following these steps:
Click Firefox.
Go to Tools.
Click on Options.
Select Privacy.
Select "Use custom settings for history" from list of the actions that Firefox will do.
Check "Clear history when Firefox closes".
Click on Settings.
Check the Cache and Cookies boxes.
Click OK to save settings.
Click OK to exit.
Hello Shannon Larry,
To clean your browser cookies you can use Ccleaner software which is available in the internet. Otherwise you can remove it manually from your browser. As you have mentioned you are using Mozilla Firefox, then at first go to the Option from Tools menu now click on the Privacy tab from there you need to select the option Clear Recent History. In the new window set ‘Everything’ under the option Time range to clear. Check the option Cookies from the Details then Clear now to finish the procedure. Hope this could be a help.
Thank you.
