Hi everyone,
What is all about google advanced search tools? What is the difference between a google advanced search tools and the basic google search engine? Share with me its difference in terms of features, additional plug ins and more. Your information will really help me to figure things out.
What is all about Google advanced search tools?
Hello! Google Search is a web engine operated by Google Inc. Google Advanced Search Tools will make your life more easy because it will search a specific topic or articles you want and it will save a lot of your time. The Google Advanced Search Tools has many queries you need to answer to shorten the list and to come up with the most specified results you want. I recommend http://www.googletutor.com/simply-advanced-google-search/, You should bookmark this website because it'll help you. I am using this one. Hope I help. Thank You and God Bless.
Google is the most popular tool to search the Internet. Most often use is Google Basic Search. Google Basic Search sorts pages that available on the Web but Google Advanced Search has the ability to retrieved better result than Google Basic Search. Google Basic Search can give you million of related and unrelated topics based from what youv'e search and Google Advanced Search can give you refined results by following the right procedures.
Hi Mellisa,
Google advanced search is for very specific searches.
These are the options –Â
You can find pages with:
1. All these words:
2. This exact word / phrase:
3. Any of these words:
4. None of these words:
5. Numbers ranging from and to:
And you can still narrow it down to more specific results by : language, region, last update, file type, etc.
The normal search is based on SEO rankings. But you can still specify it with some google search tricks.
1. You can search the time in a specific place – Just type "time in <place>".
2. Find the definition of a word – Just type "define : <word>".
3. Find by filetype – Just type "<your keyword> filetype:ppt"  (if looking for PPT).
4.Find local weather – Just type "weather: <place>".
5. Find by face – Just add the url  "&imgtype=face" to your search and the images will all be faces.
