What is all about iobit vs nod32?
Hello experts,
What is all about iobit vs nod32? Can you give me the difference between iobit and nod32? The differences about features, usage, advantages, disadvantages and most of all the security assurance that they can give to a computer registry system.
Thank you.
Answered By 0 points N/A #178522
Hello.
IObit Malware Fighter provides real-time protection against spyware, Trojans, adware and other sorts of malignant software.
In a nicely designed interface, includes all the tools you need for a safer browsing experience. The Overview window lets you check the computer’s status at a glance;
The Scan module offers three types of scan (Smart, Full and Custom); the Protect area includes eight real-time system shields, and finally, the Cloud tab, which allows you to analyzed suspicious files online.
The eight shields included in IObit Malware Fighter protect the computer’s start up, currently active processes, cookies and other elements. Should the program find any dangerous activity going on, the potentially risky files will be immediately quarantined.
IObit Malware Fighter is generally easy to use, though having a bit of documentation and more configuration settings would have been great. Also, it seemed a bit overzealous during the tests, marking standard ads as spyware. Then again, better safe than sorry!
Wile nod32 is an antivirus program for people who prefer to have simpler applications, even if that means that they have access to a limited range of tools.
This is the case of ESET NOD32 Antivirus, an anti-virus tool that you may find simpler than other similar applications, but this simplicity is precisely the key to its success. In fact, NOD32 is one of the most popular anti-virus apps among computer users.
ESET NOD32 Antivirus is easy to install and launches without even restarting the system (something most anti-virus tools require after installation). The program has a simple, straightforward design, though you'll soon discover that this is actually the Standard mode display and that you can choose the Advanced mode if you prefer to have more options and tools at your fingertips.
Regards C.S
