Hello fellows,
What is all about linux pdf reader tiny? I wasn’t able to get software that will read all my pdf files stored in my linux operating system local disks. When I tried to double click those pdf forms there is an option telling me to browse for software, I don’t have the software to open those files. I need your assistance.
Isabella Barry.
What is all about Linux PDF reader tiny?
Hi Isabella,
Linux PDF reader is a program that let you Open, Edit and Manipulate your work in PDF format. If you want other software/program, there are plenty of them but the recommended on is the adobe PDF reader. You can easily open and access any pdf file with it. Here are easy steps to install:
-First, download setup.exe which is the installer in here: http://get.adobe.com/reader/otherversions/
-After Downloading, locate the file in your folder then right click to the installer.
-Then choose run as administrator.
-When installing, choose accept.
-The setup will go the way by itself. Then that's It.
-Right click to your pdf files, and then choose open with…
-then locate adobe reader, the click it. Then click ok.
Hope it'll help
