What is all about LogMeIn access work from home?
Hi techyv,
What is all about logmein access work from home? Can logmein software application can allow the user to access the desktop at home while working in the office? What if we need files and nobody is available of operating the computer on the other end?
Hoping for your help. Thanks.
Answered By 0 points N/A #165227
“Hello”
“LogMeIn access works allows you to access your files, apps and many more your important things from your remote computer from anywhere anytime”
“It provides you work flexibility, productivity and portability.”
“Yes, it allows the user to access desktop at home while working in the office”
“If you want to access the files from the remote computer then it must be turn on and there is no need of anybody to operate as you yourself can remotely access the desktop and can operate on that computer”
“You can find much more detail information on this by visiting the following links:
https://www.logmein.com/pro
If you want to download LogMeIn and for brief step by step instructions go through:
  http://loadion.com/en/how_to/Work-Remotely-Using-LogMeIn_37632637.html
Good luck!”
