Ava larry
10 points
Posted on - 10/10/2012
Hello experts,
What is all about sql trend function? Can you give me more information about this topic or subject for I have some research and I know you have some ideas to share with me and it will help me a lot? And how it is related to server data warehousing and how it helps with financial calculations? Thank you.
What is all about SQL trend function?
How are you doing?
SQL stands for Structured Query Language. It is designed for enterprise environment and the programming language allows the users to update and/or retrieve data from the database. The standard SQL commands will be of great help in accomplishing things needed in the database.
SQL trend function is helpful in the financial calculations. It can also do rate calculations. New features have been added like the library of functions for financial activities. Most of the excel functions can be found in SQL like pric, yiel, xirr, npv etcetera.
You can also enrich your current SQL by adding more functions in this site http://westclintech.com/.
I hope this helps you.
Diane
