What is all about USB CPU usage indicator? How does it work and what is the advantage and disadvantage of this? I just want to know more about CPU and processor, how important they are in the computer information technology subject. I need to research about this and hoping for your help.
On your computer keyboard please press Ctrl+Alt+Delete and you will be at Windows Task Manager Window here please press performance button. Now you will see two sections one is about your CPU usage and other page file usage.
This function gives us the facility to check our CPU usage at any time and if we found that our CPU is overburdened with lot of applications running at the same time, then we may have to quite unwanted applications for better performance of our system.
Hi, CPU is most important part of computer. when u run software, cpu speed was going to up & down. u can check CPU speed by Task manager. usb device can effect on CPU. as u use high capacity usb device. & you attach that device on usb 2.0 version. usb device can slow work & slow read. it use more CPU speed. but that usb device attach on usb 3.0 version. it work fast. it can transfer data fast.
1....
